Print at Oct 3, 2026, 7:53:49 AM
Posted by corsica13 at May 24, 2019, 3:47:10 PM
problem displaying collada file
Hi all,
Previously when I imported collada furniture (from the 3dwarehouse sketchup) the rendering was good (with visible lines)
Now when I import a furniture I no longer see lines (the rendering is therefore less good...):
Has anyone ever had this problem?
Thank you for your help
Posted by hansmex at May 25, 2019, 5:29:29 PM
Re: problem displaying collada file
Sketchup shows the black drawing lines, plus the surfaces. SH3D only shows the surfaces. If you make a render in Q3 or Q4 the model will get some shadows and it will look better.
Posted by UbuntuBirdy at May 25, 2019, 5:40:16 PM
I even claim that the model looks better without the black lines, much more realistic. I set these edges to invisible because something like these black lines I have never seen in real life...
Posted by corsica13 at May 27, 2019, 8:54:08 PM
Thanks guys, you're right it's better without black lines
But sometimes i want them (-:
I found a solution, i open the skp file with sketchup and I select "export edges" in the collada file options
