Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: items jump on top of structure when moving them |
| Print at Sep 28, 2026, 7:48:52 PM | |
| Posted by pixelflub at May 28, 2019, 8:35:05 PM |
items jump on top of structure when moving them Hello, I have this tunnel structure from someone here on the forum, so it's not a collection item. When I move the green box the slightest bit on the floor plan, it jumps to the top of the tunnel. Every time I move it I have to set "height above ground" to 0 again. It seems the tunnel's bottom does not serve as a proper ground. Drawing a room around it did not help. Any way to fix this? https://pasteboard.co/IgPGeIO.png ![]() |
| Posted by hansmex at May 28, 2019, 8:48:27 PM |
Re: items jump on top of structure when moving them In Preferences disable Magnetism. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by alaX at May 29, 2019, 5:19:31 PM |
Re: items jump on top of structure when moving them You should specify "dropOnTopElevation" (value 0 or -1). Create library of your model and edit PluginFurnitureCatalog.properties or edit Home.xml (part of sh3d file). Library(sh3f) and project (sh3d) are zip archives - use any zip tool to extract and add files. PluginFurnitureCatalog.properties example: name#1=tunnel 1 Home.xml example: (...) |
Current timezone is GMT Sep 28, 2026, 7:48:52 PM |
