Print at Oct 2, 2026, 11:49:20 PM
Posted by pixelflub at May 28, 2019, 9:07:14 PM
cartoon like / cell shader like render?
Would it be possible to have a renderer that renders a cartoon/cell shader style to look soemwhat like the SH3D logo, with black contour lines and cell shaded areas?
Such as:
http://www.sweethome3d.com/blog/images/5.2/SweetHome3DIcon512x512.png
Posted by hansmex at May 29, 2019, 11:38:48 AM
Re: cartoon like / cell shader like render?
- Make your design in Sketchup
- Export as 3D model - AND -
- In Options check "Export Edges"
This option inludes the black lines on the edges in the model.
PS
No doubt there are other ways to achieve the same result...
Posted by VeroniQ at May 29, 2019, 9:54:09 PM
I don't think it answers to your question, but if you want, I can send you the "real" model I did for the illustrations of this survey (see also the different versions I did for the survey itself).
Posted by digitaltrails at Jun 1, 2019, 11:02:52 AM
You could post-process the SH3D image with a tool such The Gimp. Applying posterization and cartoon filters won't quite look as clean as the posted example, but it will certainly achieve the black shadowing.
