Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Roadmap |
| Print at Oct 16, 2026, 11:32:42 AM | |
| Posted by ichklaus at Nov 15, 2007, 4:10:00 PM |
Roadmap Is there a roadmap? When approximately will version 1.3 be launched? In January? I´m looking forward to it... Good job puybaret! Keep it up! Best wishes! Klaus [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Nov 15, 2007, 6:22:00 PM |
Re: Roadmap Thank you for launching this discussion about Sweet Home 3D roadmap. I wanted to create a web page for it, but finally this forum is the easiest way. Here's the features roadmap I've got in mind at this time: - v 1.3 : creation and modification of home rooms, with textures applicable to room's floor and cellar - v 1.4 : ergonomic stuff : automatic depth of windows and doors placed on walls, stick and orientate objects to the approach of a wall, better management of magnetism - v 1.5 : management of lights - v 2.+ : management of multiple floors, roofs, export to other formats... v 1.3 shouldn't be available before February or March 2008 (I have to earn some money first ;-). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Feb 10, 2008, 8:43:00 PM |
Re: Roadmap Just this message to announce that probably, Sweet Home 3D v 1.3 won't be available before this summer, because I don't have enough free time right now to program more things that maintenance releases. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jeroen_roeterd at Mar 4, 2008, 7:36:00 PM |
Re: Roadmap Hello, Just letting you know that I discovered your application just hours ago and like it very much. The features you name in later releases would make it much better (spec. floor and cellar textures). Keep up the good work (after earning a living of course ;-)) Greetings form the Netherlands, Jeroen |
| Posted by Wolf_Skafte_Zauss at May 30, 2008, 2:08:00 AM |
Re: Roadmap Hi there I love your project and was wondering if there is any way of of making it a web based application. My idea is to offer our customers the facility to create their own floor plans on-line. Any information on this would be appreciated and if we could make this happen then I would be happy to become a sponsor for your project. Have a great day Wolf Skafte-Zauss Contemporary Door & Cabinet Hardware specialists. http://www.bluewolf.net.au 1300 738 936 Fax: 02 9012 0193 |
| Posted by Puybaret at Oct 8, 2008, 12:08:00 PM |
Re: Roadmap From the description of versions 1.3 and 1.4 at http://sweethome3d.sourceforge.net/history.html , you may guess that the roadmap proposed one year ago changed a little. ;-) So, here's the new roadmap I've got in mind at this time: - v 1.5 : creation and modification of home rooms (with textures applicable to room's floor and cellar), and creation of free text labels in the plan - v 1.6 : ergonomic stuff : automatic depth of windows and doors placed on walls, stick and orientate objects to the approach of a wall - v 1.7 : management of lights - v 2.+ : management of multiple floors, roofs... Meanwhile, I might also test an on-line applet version of Sweet Home 3D. I prefer to promise no delivery date, but be reassured, I'm still spending a lot of time on Sweet Home 3D development. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vincecat at May 7, 2009, 12:42:00 AM |
Re: Roadmap Bonjour monsieur Puybaret. Un grand merci pour votre travail. J'utilise Sweet Home 3D depuis la v1.3 et je suis toujours autant impressionné par la simplicité de SH3D au regard de sa puissance. La dernière petite merveille, l'online applet, est sur mon site (ecolonomiqhome.free.fr). Elle fonctionne aussi bien que le reste. J'ai un peu honte, surtout que je ne vous ai pas encore fait de don, de vous demander un ajout à votre roadmap: - pourriez-vous ajouter l'export DXF ou DWG en plus du SVG. Les raisons de cette demande sont l'échec de conversion du SVG, créé par SH3D, en DXF via Inkscape (je peux vous faire parvenir les fichiers ainsi que les messages d'erreur d'Inkscape si vous le souhaitez). Le format DXF est le plus commun pour l'import de plan dans les logiciels du bâtiment comme Alcyone+Comfie+Pleiade (simulation thermodynamique) et Dialux (simulation d'éclairage). En tout cas, que vous le fassiez ou pas, un grand merci d'avoir créé SH3D. Cordialement. |
| Posted by Puybaret at May 7, 2009, 2:43:00 PM |
Re: Roadmap Pour ne pas alourdir le logiciel, je ne pense pas ajouter d'autre format d'export dans un avenir immédiat (à part peut-être pour les images de la vue 3D), mais ce genre d'exportation pourrait être réalisé à l'aide d'un plug-in (y'a-t-il un volontaire dans la salle ? ;-). Il existe peut-être aussi un convertisseur autre que Inkscape qui fonctionne... Vous pouvez aussi signaler le bug à l'équipe d'Inkscape pour qu'ils essaient de le corriger. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vincecat at May 7, 2009, 11:19:00 PM |
Re: Roadmap Je comprend. Pour le convertisseur qui fonctionne, oui il y en a un: ivcon (un executable en ligne de commande trouvé ici). Mais la visu sous Comfie, confirmée avec Cadviewer, du DXF obtenu m'a vraiment surpris. Inexploitable dans mon cas. Merci et bonne continuation pour la v2. Cordialement |
| Posted by Puybaret at Aug 7, 2009, 11:55:00 AM |
Re: Roadmap Now that version 2.0 is out, here's a list of the main features that will probably appear in the 2.+ releases: - Grouping/ungrouping furniture - Better furniture catalog pane for catalog containing many pieces - New Display menu to let user choose which pane to display - New wizard to create 3D models from pictures applied on the faces of a cube, sphere or cylinder - Creation of videos from a virtual visit - Improvement of lights management - Management of levels - Management of roofs - Manage portability to simplify the moving of Sweet Home 3D ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Francois at Oct 3, 2009, 5:34:07 PM |
Re: Roadmap Excellent! Sounds like some of them will be really nice improvements. Is this roadmap in order of priority/developpement? |
| Posted by Puybaret at Oct 6, 2009, 8:45:59 AM |
Re: Roadmap Is this roadmap in order of priority/developpement? More or less. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Dec 2, 2010, 8:53:03 PM |
Re: Roadmap Now that version 3.0 is out, you may wonder what will be on the menu in the coming releases. ![]() So here's a list of the main features that will probably appear in the 3.+ releases: - Management of levels - Management of roofs - New wizard to create one room from a default shape (rectangular, L shape, U shape) - New wizard to create 3D models from pictures applied on the faces of a cube - Better color and date/time choosers - New palettes to edit the attributes of furniture, walls, rooms and other selectable items. I'll also add pages on sweethome3d.com for plug-ins and web sites that propose textures. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Dec 2, 2010, 10:01:44 PM |
Re: Roadmap Emmanuel, On December 6 we celebrate "Sinterklaas", sometimes imitated and called Santa Claus a few weeks later. Whatever the name, it's time to make lists with all the goodies we hope to receive. I'm trying to picture you in a red cape and a huge white beard... be warned! Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Dec 2, 2010, 11:41:58 PM |
Re: Roadmap Gosh! I think you disclosed me, I wish the latest v3 would be a surprise. And for the v4, be patient. The Christmas software factory is already overloaded! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sampathmalaka at Dec 29, 2010, 1:27:49 PM |
Re: RoadmapFeatures indeed!!! Gr8! for ur gr8 work! |
| Posted by live at Jan 7, 2011, 10:06:42 PM |
Re: RoadmapFrom your list, my top 3 in order: 1/ New wizard to create 3D models from pictures applied on the faces of a cube 2/ New wizard to create one room from a default shape (rectangular, L shape, U shape) 3/ Management of roofs one level at a time :-) Thanks |
| Posted by live at Jan 7, 2011, 10:14:19 PM |
Re: Roadmap >New wizard to create 3D models from pictures applied on the faces of a cube This "trompe l'oeil" technique would allow to swiftly create for instance a sauna, a shower, a car, a miror with its light simply by starting with a cube and projecting simply between 1 & 3 pictures ! But please consider at the same time a polyhedron http://en.wikipedia.org/wiki/Polyhedron So that one can create for instance a hexagonal table or greek column :-) |
| Posted by magi6162 at Jan 21, 2011, 2:30:41 PM |
Re: Roadmap 1. Management of levels 2. Management of roofs very best work!!!! bye |
| Posted by Jradwans at Mar 29, 2011, 9:31:02 PM |
Re: Roadmap 1. Management of levels 2. Management of roofs Can you tell me when it will be works? This very important for me. |
| Posted by Puybaret at Mar 30, 2011, 7:48:55 AM |
Re: Roadmap Can you tell me when it will be works? I don't think any new big feature will appear in the coming months. This is a volunteer work and I have to earn money too.If it's very important for you, you should have a look to the Documentation page for workarounds or give a try to the other software which already offer this feature. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Mar 30, 2011, 7:54:52 AM |
Re: Roadmap To manage levels, check out this tutorial (PDF). To make roofs, try this tutorial (PDF). ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by 2trickpony at Mar 30, 2011, 10:14:46 AM |
Re: Roadmap Management of levels would be my priority. I hate workarounds 8-) !! I am patient and will wait until you have time to continue development. Keep up the good work, Stu |
| Posted by jasan at Dec 30, 2012, 8:05:16 PM |
Re: Roadmap (Once again) thanks for the program and great work! Whenever you have time it would be very nice to know to have an update in this thread to get an idea about what features that we might (not) expect in the upcoming year. Another thought/question that may be a bit offtopic for this thread; Have you ever considered to completly open up source/development for SH3D so that other developers could contribute code to the core of SH3D? ...and a happy new SH3D year! ;-) |
| Posted by Puybaret at Dec 30, 2012, 8:58:35 PM |
Re: Roadmap Whenever you have time it would be very nice to know to have an update in this thread to get an idea about what features that we might (not) expect in the upcoming year. It's difficult to say. Some features appear because users request them, some others because some companies pay for them and I also choose myself in the list depending on my mood. And of course, it depends on the free time I can spend on programming new features, because Sweet Home 3D doesn't provide enough money to let me spend all my time on it.Have you ever considered to completly open up source/development for SH3D so that other developers could contribute code to the core of SH3D? Sweet Home 3D is completely open source already and distributed under GNU GPL. Once in a while, I receive some proposal from developers who want to contribute to the program, but strangely, they rarely go further.Happy new year to everyone! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Vkbear0 at Aug 26, 2015, 1:59:51 AM |
Re: Roadmap I really appreciate your work! It allows my creativity just flow. I understand it is voluntary, which makes this even more fascinating to me. If I knew programming, I would help, but I dont. Thank you!! ---------------------------------------- -The Hobbyist |
Current timezone is GMT Oct 16, 2026, 11:32:42 AM |
