Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to solve this roof issue? |
| Print at Sep 28, 2026, 12:56:37 PM | |
| Posted by MichaelN at Jul 13, 2019, 11:14:26 AM |
How to solve this roof issue? When I activate the roof in the room options then I see a grafic issue. See pictures. How could I solve it without creating my own roof out of boxes? ![]() |
| Posted by hansmex at Jul 13, 2019, 11:47:51 AM |
Re: How to solve this roof issue? Same old story... the walls surrounding the room are not of equal height. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by MichaelN at Jul 13, 2019, 2:39:58 PM |
Re: How to solve this roof issue? I just checked it. The surrounding walls are all at the same height. Behind the door starts a wall with different level, but this shouldn't be influence this room?! |
| Posted by hansmex at Jul 13, 2019, 2:48:48 PM |
Re: How to solve this roof issue? Simple test: make your ceilings invisible. If the anomaly disappears, you know where to look to solve the problem. If you need help, send me your file. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by MichaelN at Jul 14, 2019, 3:47:25 PM |
Re: How to solve this roof issue? Sure is the issue gone, if I deactivate the ceiling. See also picture #3. Can't find the issue. I edited the walls several times. Could it help to delete the room and create him again? |
| Posted by Mike53 at Jul 14, 2019, 3:59:38 PM |
Re: How to solve this roof issue? Cannot tell much from your images, something you could try is to extend the room slightly beyond the walls, to mid wall, in the area giving an issue. I did notice, in the 2d image, 3 points in the room set up that are not needed, delete them too, 1 on the corners each side of the viewer. Try to keep images a little smaller, give a better overall picture. Mike |
| Posted by Mike53 at Jul 14, 2019, 4:05:13 PM |
Re: How to solve this roof issue? If that does not help then i would suggest you make all objects except doors hidden, save the file to share here, perhaps Hans or myself could spot something that would help |
| Posted by Mike53 at Jul 14, 2019, 11:19:44 PM |
Re: How to solve this roof issue? or... change the room settings so it shows no ceiling... make a copy... modify the copy to show only the ceiling, no walls or floor.....export it...import and position, one drawback is you will probably have to hide it when moving other objects in the hallway |
Current timezone is GMT Sep 28, 2026, 12:56:37 PM |
