Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Double Wall Windows and Doors |
| Print at Oct 18, 2026, 1:25:49 AM |
| Posted by Mike53 at Aug 2, 2019, 11:17:23 PM |
Re: Double Wall Windows and Doors Not sure i fully understand what it is you are trying to achieve, in order to give further advise i think you need to show images or maybe share your file, either way would help us understand what the difficulties are, especially since positioning windows, even into a double skinned wall, should be easy. |
| Posted by KitchM at Aug 4, 2019, 8:36:24 PM |
Re: Double Wall Windows and Doors http://www.mediafire.com/file/y37d08nrn04xr5x/Corner_Window.sh3d/file |
| Posted by Mike53 at Aug 4, 2019, 8:43:57 PM |
Re: Double Wall Windows and Doors quick question are your walls really 640 mm thick |
| Posted by KitchM at Aug 4, 2019, 9:28:18 PM |
Re: Double Wall Windows and Doors I have an eight inch concrete block wall, a fourteen inch space and a second wall of two by three or fours. |
| Posted by Mike53 at Aug 4, 2019, 9:53:44 PM |
Re: Double Wall Windows and Doors ok. try this its not fancy but it fills the hole |
| Posted by Mike53 at Aug 4, 2019, 9:58:56 PM |
Re: Double Wall Windows and Doors the group of box's and the opaque wall i used to create are all still there, if you wish to modify any of them to create your own, you will now at least be able to see how it is done, once happy with it, export it then import it but check the box that says "door or window" when you are importing it. |
| Posted by KitchM at Aug 12, 2019, 7:49:37 PM |
Re: Double Wall Windows and Doors Thanks. I'll give it a try. |
Current timezone is GMT Oct 18, 2026, 1:25:49 AM |
