Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Cavity walls without a redesign... |
| Print at Aug 27, 2026, 1:49:13 PM | |
| Posted by Mike53 at Aug 2, 2019, 2:06:14 PM |
Cavity walls without a redesign... I know the topic of cavity walls has been raised several times, to my knowledge, which is only a few years, but with it being raised again recently i was wondering if, in a future release, the drop down box with the wall hatching patterns could include an option for a cavity, this would enable people who are creating projects in order to print plans would have a much more realistic image without the need to actually create the cavity, which, i would imagine is a huge change to the basic programme, and would create issues with windows, doors, wall lengths, area calculation etc just a thought. MIke |
| Posted by KitchM at Aug 2, 2019, 2:18:08 PM |
Re: Cavity walls without a redesign... Please define "cavity walls". Thank you. |
| Posted by Mike53 at Aug 2, 2019, 2:44:47 PM |
Re: Cavity walls without a redesign... mmmmm h**ps://www.google.com/search?q=cavity+wall&rlz=1C1CHBD_en-GBGB818GB818&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiC26_zqOTjAhXDrHEKHVdBCAEQ_AUIESgB&biw=1920&bih=950 |
| Posted by Bubblobill at Aug 3, 2019, 4:12:13 PM |
Re: Cavity walls without a redesign... +1 for me. I live in an area where everything is built out of double-brick cavity walls. |
| Posted by hansmex at Aug 3, 2019, 8:17:27 PM |
Re: Cavity walls without a redesign... Netherlands: cavity walls are mandatory. ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Bubblobill at Aug 4, 2019, 6:29:00 AM |
Re: Cavity walls without a redesign... No doubt it helps things float when the dikes fail. |
| Posted by hansmex at Aug 4, 2019, 7:23:47 AM |
Re: Cavity walls without a redesign... Dikes fail in the USA, not in NL... :-) ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by DanielJ at Nov 26, 2019, 3:56:31 AM |
Re: Cavity walls without a redesign... This may be added as an additional function. Different countries or even cities have their own specific materials or building regulations. For example, I need an empty wall, I press a button and automatically start building it. |
| Posted by Mike53 at May 30, 2020, 7:44:30 PM |
Re: Cavity walls without a redesign... I am aware that this software has developed massively over the last few years with the addition of yarafray, moving models and the police forensics, but i have to wonder if a couple of the more basic items could be revisited, like cavity walls, baseboard on the end of walls and discovering why ceilings react the way they do when used with uneven wall heights. Just a thought |
| Posted by Gildaniel at Jun 1, 2020, 1:35:22 PM |
Re: Cavity walls without a redesign... Double walls can be made this way: 1. Draw room. 2. Put new walls thikness 50cm in preferences 3. Doubleclick your room with walls tool - you get walls around. After change their thickness to 10cm 4. Put new walls thikness 10cm in preferences 5. Doubleclick once again. In my opinion, most of basic tools the SH needed - lateral view for walls and some roof generator |
| Posted by hen3bosch at Aug 23, 2020, 8:05:30 PM |
Re: Cavity walls without a redesign... This doesn't work. When you put a door in the outer wall and you open it then you are looking at the inner wall. hen3 |
| Posted by gregoryx at Nov 3, 2020, 11:58:19 PM |
Re: Cavity walls without a redesign... Not an ideal solution, but I've had to do this a few times to deal with such a wall: install the door, then change the width of the door (10-inches instead of 3-inch, for example), then use the arrow keys to move the door to cover both walls. PITA, but works. 🤷♀️ |
| Posted by AlbertKakiay at Feb 25, 2021, 3:58:33 PM |
Re: Cavity walls without a redesign... No need redesign, add new wall as skin with cavity space. Adjust door and window. I call it Skin, the same structure with different facade. |
| Posted by Mike53 at Feb 25, 2021, 7:28:10 PM |
Re: Cavity walls without a redesign... I have a feeling my point has been misunderstood. Draw a wall as per normal, open the modify walls dialogue box, select the NEW Cavity wall hatching. Windows and doors then act as normal, without the need for extra walls or positioning issues. Any printed docs would then appear to have cavity walls Very small programme change compared to to creating actual cavity walls |
Current timezone is GMT Aug 27, 2026, 1:49:13 PM |
