Print at Sep 28, 2026, 11:36:04 AM
Posted by Mike53 at Aug 4, 2019, 1:03:59 PM
Level modification
Would it be possible, on a future version, instead of opening each levels modification window to make changes, have the ability to open 1 window where we can modify all the levels by selecting them, use the same window that is available now, but be able to select which level to modify..... pretty please
Posted by UbuntuBirdy at Aug 4, 2019, 1:10:23 PM
Re: Level modification
Oh yes, would love this feature!
Posted by Mike53 at Aug 4, 2019, 1:11:45 PM
Another request would be to be able to set the wall height to 0. I use rooms to create a number of objects, but, when exported/imported the texture often looks awful on its sides, to overcome this, i surround the room with a very thin wall, this works fine, except it is always a different height to the room, 1 mm, this can be overcome by exporting them as separate objects, but seems unnecessarily long winded.
Posted by Mike53 at Aug 4, 2019, 1:12:22 PM
Glad you like it birdman biggrin
