Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: It would be great if text size on dimentions was the same as on dimension tip, depending of current zoom |
| Print at Sep 28, 2026, 10:15:56 AM | |
| Posted by Gildaniel at Aug 14, 2019, 1:45:52 PM |
It would be great if text size on dimentions was the same as on dimension tip, depending of current zoom When I point mouse to see tip dimension it showing with appropriate readable size, but after I doubleclick to put this dimension it became to small and I need to press ctrl+alt+K many times to discern it. The same when I put free dimensions without tip - they are always need adjusting, although current scale is enough information to presume readable dimension size. Could you please put dimensions with the same text size as on tips? |
Current timezone is GMT Sep 28, 2026, 10:15:56 AM |
