Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I delete a section of a wall (create a room) |
| Print at Sep 30, 2026, 8:12:48 PM | |
| Posted by fabtech at Aug 19, 2019, 6:07:25 PM |
How do I delete a section of a wall (create a room) Hi all, I am a newbie and have a question for the pros: I am creating a 2D plan for a flat remodel to give to my contractor: I created 3 adjacent rooms (no external wall yet). A section of a wall that is common to two rooms will be removed in order to create a larger room (a kitchen). The room will no longer be a rectangular shape. Now, how do I 'delete' the section of the wall in order to open up the two rooms? Does the SH3D software allow to delete sections of a room or walls? If not, how would you perform this operation in 2D? Thanks!! |
| Posted by dorin at Aug 20, 2019, 6:38:21 AM |
Re: How do I delete a section of a wall (create a room) For wall question: 1. Select the wall between two rooms; 2. Right click on selected wall; 3. Split wall; 4. Delete one section; 5. Resize the remaining section to Your desire length. For room question You have two options: 1. Delete one room & resize manually the remain.(It's a little bit hard) 2. Delete both rooms & recreate automatically by double clicking inside the new walls area. (It's the easy one) ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 30, 2026, 8:12:48 PM |
