Print at Sep 29, 2026, 2:57:22 PM
Posted by RiffRaffMama at Aug 24, 2019, 9:27:57 AM
confused   Mirroring walls
Hi, I have a large amount of walls which are joined at unusual angles, and I would like to copy and paste them, but in mirrored orientation (for the other side of a building) but there is no <- to grab to turn them around. Is there an easy way to do this, or do I just have to reproduce each one manually?
Posted by waleedfahmy at Aug 24, 2019, 10:03:52 AM
Re: Mirroring walls
hello ,
I am not sure if I understand your question , better if you post a screenshot illustration , but if you want to mirror a group of walls you can select them then copy and paste the new pasted walls will be now marked as selected , just right click and flip them horizontally or vertically but be careful not to lose selection by clicking away .
another way by using "copy as new furniture " plugin http://www.sweethome3d.com/plugins/CopyAsNewFurniturePlugin-1.2.sh3p select walls you want and copy as new furniture then paste and flip in the direction you want .
I hope it is helpful .
Regards
Posted by RiffRaffMama at Aug 25, 2019, 9:25:58 PM
Re: Mirroring walls
Thank you! Flipping them as a group did exactly what I needed.
Posted by waleedfahmy at Aug 25, 2019, 10:31:15 PM
Re: Mirroring walls
you are welcome
