Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: YafaRay rendering plug-in |
| Print at Oct 1, 2026, 1:29:11 AM |
| Posted by son87a at Oct 31, 2021, 10:43:23 AM |
Re: YafaRay rendering plug-in @Puybaret I want to build a cloud render for SweetHome3DJS. Is it possible ? Do you have any suggest for that ? |
| Posted by Puybaret at Oct 31, 2021, 1:08:11 PM |
Re: YafaRay rendering plug-in That would be nice and surely possible ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Poffu at Dec 29, 2021, 12:10:11 PM |
Re: YafaRay rendering plug-in Do you have ideas on how to get gray wall renderings to represent the true color it would have? I'm trying to see whether I'd like to have the lighter gray on my walls or the darker one, but the darker shades of gray get rendered way too light (if you ask me ).Here are the walls pre-rendered: Color L500 (RGB #A8AFB5): ![]() and color S500 (RGB #757B81): and their corresponding renderings: L500: S500: ![]() |
| Posted by hansmex at Dec 29, 2021, 1:55:10 PM |
Re: YafaRay rendering plug-in Try using textures of the desired colours instead of the colours themselves. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Xiste at Dec 29, 2021, 2:38:24 PM |
Re: YafaRay rendering plug-in Agree with Hansmex. I used a site like this https://www.magasindepeinture.ch/en/ncs-color-chart-online.html to find the right color combo for my studio. I sampled the color images, named them with the NCS code, applied them to my walls and made renderings. Having found the right ones, I gave the NCS code to the painters. Perfect result. Xiste |
| Posted by narensankar0529 at Jan 19, 2022, 3:25:02 PM |
Re: YafaRay rendering plug-in Plugin seems to crash on both macOS Intel and macOS M1 with 6.6. Home renders correctly with SunFlow but no matter what dimensions I use it starts rendering but then crashes. Anyone else seeing this issue? Path: /Applications/Sweet Home 3D.app/Contents/MacOS/SweetHome3D Identifier: com.eteks.sweethome3d.SweetHome3D Version: 6.6 (6600) Code Type: X86-64 (Native) Parent Process: launchd [1] User ID: 501 Date/Time: 2022-01-19 23:24:15.9346 +0800 OS Version: macOS 12.0.1 (21A559) Report Version: 12 Bridge OS Version: 6.0 (19P549) Anonymous UUID: 061D21FF-1D40-DCCA-7BA1-0F5EC4683531 Time Awake Since Boot: 2500000 seconds System Integrity Protection: enabled Crashed Thread: 152 Exception Type: EXC_BAD_ACCESS (SIGABRT) Exception Codes: KERN_INVALID_ADDRESS at 0x000000000000000c Exception Codes: 0x0000000000000001, 0x000000000000000c Exception Note: EXC_CORPSE_NOTIFY VM Region Info: 0xc is not in any region. Bytes before following region: 4505481204 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL UNUSED SPACE AT START ---> __TEXT 10c8c3000-10c8d6000 [ 76K] r-x/rwx SM=COW ...S/SweetHome3D Application Specific Information: abort() called |
| Posted by mickut at Jan 25, 2022, 9:41:44 PM |
Re: YafaRay rendering plug-in On Win10 my project has started to consistently crash Yafaray as well on memory access violation. The fault offset is constant. Faulting application name: javaw.exe, version: 11.45.0.27, time stamp: 0x5fece988Happens with both installer version and downloaded JAR on JDK-11 (not suprising, as it's the yafaray dll). |
| Posted by Daniels118 at Jan 26, 2022, 9:19:31 AM |
Re: YafaRay rendering plug-in Does this happen even with a very simple home (i.e. just 4 walls and floor), or is it specific to this file? In the second case can you upload the file somewhere and share the link? |
| Posted by mickut at Jan 27, 2022, 5:12:15 PM |
Re: YafaRay rendering plug-in A minimal project renders fine, and even some close-ups in the failing model. I'll try to isolate the feature, then either create a sample or share the actual model. |
| Posted by mickut at Jan 27, 2022, 8:10:23 PM |
Re: YafaRay rendering plug-in Found the issue. A seemingly innocent looking model of a Denon LP player downloaded as Collada file: https://3dwarehouse.sketchup.com/model/146e08...6a3/Denon-SL-7D-Turntable Works almost OK with SunFlow, crashes YafaRay instantly. When I change "edge_color*" invisible in materials, it works. The resulting non-crashing render does have some texture or surface clipping issues (and I've noticed it on many other models from 3dWareHouse as well). |
Current timezone is GMT Oct 1, 2026, 1:29:11 AM |
