Print at Sep 26, 2026, 3:58:11 AM
Posted by MichaelN at Sep 15, 2019, 4:36:26 PM
Photo rendering shows bad image quality
Why I see such noisy pictures after rendering in quality level 3?
https://we.tl/t-Bgvulpet77
Posted by hansmex at Sep 16, 2019, 1:26:23 PM
Re: Photo rendering shows bad image quality
If you don't like it, did you try Q4 ??
As an alternative, you could try Enkonyito's plugin, in which you can "play" with the settings to get excellent quality.
Posted by MichaelN at Sep 16, 2019, 4:37:53 PM
On Q4 is Image quality a little bit better, but also not "clear". And it last much longer.
So, for Q3 this noisy picture is the quality I could expect?
Posted by VeroniQ at Sep 16, 2019, 6:24:47 PM
You may try also this new plugin or follow also some of these tips.
Posted by Ceciliabr at Sep 18, 2019, 3:46:13 PM
YES!
To get a high quality rendering with a CPU-renderer, you have to be patient.
Your CPU determines the rendering speed, and the time needed to perform a quality rendering will be more or less equal when producing the same quality image – no matter what CPU based renderer you choose.
A high quality rendering may take several hours, maybe even days.
