Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Livingroom in new apartment |
| Print at Sep 25, 2026, 9:48:57 AM | |
| Posted by timegroove at Oct 5, 2019, 11:30:17 AM |
Livingroom in new apartment Hi! After buying a new apartment that was not even built yet, I wanted a program that would let me visualise it and to try some different interior ideas. After some googling I found Sweet Home 3D and made a model of the apartment. Here is a design I did of the living room. /Timegroove ![]() |
| Posted by VeroniQ at Oct 5, 2019, 11:28:34 PM |
Re: Livingroom in new apartment Well done and very smart! However, the thin lights, especially on the doors at the right side, are a little bit odd. Are you sure that your room joins totally your walls? |
| Posted by maureenowaters at Oct 9, 2019, 5:59:50 AM |
Re: Livingroom in new apartment Congrats on it's, it's really so beautiful, just love it. |
| Posted by Bartosz at Oct 11, 2019, 6:15:58 PM |
Re: Livingroom in new apartment Good job. I especially like the models, however VeroniQ made a good point, I also noticed sun leaks. I recommend to re-doble click all your floor corners to make them match wall corners or even overlap them, then your celiling will be sealed as well. I had the same bad experience - when your main plan is not locked then it's very easy to accidently move the floor when working on models. I appreciate your work on lighting. Can you make some other angles? |
| Posted by timegroove at Oct 17, 2019, 12:51:35 PM |
Re: Livingroom in new apartment Thank you all for your comments. :) Yes, I noticed some sun leaks on the right side, but I ignored it so far, I should try to fix it. On the left side is a window and a door that is open, that is why there is sun coming in. Maybe I can make some other angles. The light is setup so it looks good from this angle, I will try and see how it looks from other angles. |
| Posted by bdfd at Nov 1, 2019, 6:22:09 AM |
Re: Livingroom in new apartment Hi, Great art ! . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
Current timezone is GMT Sep 25, 2026, 9:48:57 AM |
