Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Graphic issue - any hints? |
| Print at Sep 26, 2026, 8:59:21 PM |
| Posted by MichaelN at Oct 26, 2019, 2:25:38 PM |
Graphic issue - any hints? I see this graphic issue (rendering with best quality). What can I do to avoid this? Or it's an issue with the model? Picture |
| Posted by Ceciliabr at Oct 27, 2019, 4:44:49 PM |
Re: Graphic issue - any hints? Had the same problem some years ago. ![]() My solution: Import to Verto Studio 3d ( free program) and export obj. file. Problem solved. You can probably do the same with Blender, also free. cec _________________________________________________________________ EDIT: If you are working on a Mac or iPad, Verto Studio is still free. The Windows version is no longer free. Sorry. Thank you Hans :) CEC |
| Posted by alaX at Oct 28, 2019, 9:55:02 AM |
Re: Graphic issue - any hints? Make material on back faces of your model invisible. ![]() |
| Posted by hansmex at Oct 28, 2019, 11:46:17 AM |
Re: Graphic issue - any hints? Verto Studio 3D now costs €16.79 ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Ceciliabr at Oct 28, 2019, 7:31:27 PM |
Re: Graphic issue - any hints? Verto Studio 3D now costs €16.79 That is the VR-version ( which is incredible!). The standard version is still free. ![]() Make material on back faces of your model invisible. Works sometimes. See if you can make it work on this: Hummer-no-black.zip cec |
| Posted by hansmex at Oct 28, 2019, 8:32:51 PM |
Re: Graphic issue - any hints? Dear Cecilia, Believe me, I don't doubt what you say or write. Before writing my answer I searched for "free version" but without result. I would be very interested if you could provide a link to the free version. If you search my posts, this same issue has caused me problems for many years. Thanks in advance. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Ceciliabr at Oct 28, 2019, 9:38:48 PM |
Re: Graphic issue - any hints? https://vertostudio.com/desktop.php This link takes you to the download page. For Mac it points to Appstore, where the app is free, for Windows( Linux/others, I don't know, since the website obviously sees what platform is making the request, and leads me to Appstore. Cec |
| Posted by hansmex at Oct 29, 2019, 7:28:21 AM |
Re: Graphic issue - any hints? Hi Cecilia, I found that page as well. Unfortunately Apple-only. Thanks anyhow. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Ceciliabr at Oct 29, 2019, 7:58:49 AM |
Re: Graphic issue - any hints? Hm... It seems you're right. The standard version is no longer available for Windows. Cec |
| Posted by MichaelN at Oct 29, 2019, 6:52:25 PM |
Re: Graphic issue - any hints? The tip with making surface invisble doesn't worked. Blender is an idea, I will test it in the next few days. Thanks. |
Current timezone is GMT Sep 26, 2026, 8:59:21 PM |
