Print at Oct 13, 2026, 7:19:13 PM
Posted by BohoRex at Nov 24, 2019, 10:35:21 PM
Through-Wall applieances
I am designing a small cabin, and plan for cooling is to use an off-the-shelf air conditioning window unit - framed into a wall instead of mounted in a window.
Is there a way to edit an item of furniture (3D object import) so that it can be mounted **through** a wall (just as a window or doorway is placed onto a wall) ?
I imported the closest thing I could find - a bathroom fan from the 3D models listing - however, it wants to be placed wither completely inside a wall or completely outside of a wall. I need it to go through the wall. I'm certain there's a setting somewhere - but I'm just not finding it yet.
Thanks,
BohoRex
Posted by Puybaret at Nov 25, 2019, 10:33:54 AM
Re: Through-Wall applieances
You can move objects anywhere on the plan with keyboard arrows or with disabled magnetism. See help to learn how to disable magnetism.
Posted by BohoRex at Nov 26, 2019, 5:32:57 AM
Thank you! That was way too easy! (once the method was pointed out to me). Arrow keys did the trick. I'll investigate the other method later.
Posted by Puybaret at Nov 26, 2019, 12:25:06 PM
Don't wait too long! wink
Magnetism is useful for many other things as explained in this video.
Posted by BohoRex at Nov 26, 2019, 4:16:33 PM
A great set of video tutorials to binge-watch!
