Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can I superimpose one image on another? |
| Print at Oct 13, 2026, 3:40:00 PM | |
| Posted by pjw359 at Nov 25, 2019, 12:43:54 AM |
Can I superimpose one image on another? I'd like to view a first and second image in respective levels superimposed, at the moment each image is a background image in a level but I can't see to view them together. My best work around is to superimpose the images using GIMP and then use a single combined usage ... but this is not ideal. |
| Posted by Puybaret at Nov 25, 2019, 10:38:19 AM |
Re: Can I superimpose one image on another? There's only one background image per level as you noticed. You could apply an image as a texture on the top of a thin box. This tip may give you also more ideas. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by DanielJ at Nov 26, 2019, 3:29:46 AM |
Re: Can I superimpose one image on another? Can we set macraces on this topic? I have a number of identical objects with different variables that will change slightly. |
Current timezone is GMT Oct 13, 2026, 3:40:00 PM |
