Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Different floor textures in different rooms? |
| Print at Sep 24, 2026, 6:37:18 AM |
| Posted by mnemix at Dec 16, 2008, 8:08:00 PM |
Re: Different floor textures in different rooms? YEAHHHH; I have it, I have it!!! I've found a bug!!!! The problem is that I'm using SH3D in Spanish. Try to change the language and try to obtain this dialog box, can you? If I change the language to English, I can see this dialog box, but not in Spanish. I've checked it in all languages, and only fails in Spanish... I was going a little mad... Please check it and try to improve it for the next version. Thanks |
| Posted by Puybaret at Dec 16, 2008, 8:09:00 PM |
Re: Different floor textures in different roo You must select the room first, then you can modify it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Dec 16, 2008, 8:27:00 PM |
Re: Different floor textures in different roo Thank you very much for your advanced search. :-) Miserably, I found also some problems in the Brazilian version when you want to modify a piece of furniture or the page setup. I fixed the bug in the source files and probably release a new version in the coming days... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Dec 17, 2008, 11:21:00 PM |
Re: Different floor textures in different roo I released the version 1.5.1 to fix this bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 6:37:18 AM |
