Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Ceiling on lower floor overridden with floor on upper floor |
| Print at Oct 13, 2026, 3:46:31 PM | |
| Posted by monstera at Dec 11, 2019, 2:09:41 PM |
Ceiling on lower floor overridden with floor on upper floor Hello, I have searched in vain for an answer to this apparent bug. In my two-floor simulation, choosing a floor on the upper level (for example, gray wood), overrides any ceiling choices on the lower level. That way, when looking up on the lower level, instead of a normal ceiling, you see the gray wood floor of the above room. The "show floor/ceiling" box is checked for both rooms. The only space where I am able to choose a ceiling color is for those areas of the upper floor that have not been defined as a "room". Thank you. |
| Posted by Puybaret at Dec 12, 2019, 12:05:15 PM |
Re: Ceiling on lower floor overridden with floor on upper floor You should also define some rooms at the lower floor, to be able to change their ceiling. Reading this tip might help you understand how ceiling/floor colors work too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gildaniel at Dec 12, 2019, 7:28:26 PM |
Re: Ceiling on lower floor overridden with floor on upper floor Probably, elevation of upper level is not enough and equal to height of the lower level. Floor goes down and mixing with ceiling. Check the elevation of second level, it should be Height of first level + floor thickness of second level |
| Posted by monstera at Dec 13, 2019, 10:00:03 AM |
Re: Ceiling on lower floor overridden with floor on upper floor Yes, this appears to be an issue with floor levels and floor thickness, tweaking these settings has resolved the issue. Thank you. |
| Posted by monstera at Dec 13, 2019, 10:05:54 AM |
Re: Ceiling on lower floor overridden with floor on upper floor Another related question is why it's not possible to move levels up and down in the levels setting. I started by creating the second floor first, and afterwards it was not easy to create a lower level. Apparently it's much easier to create an upper floor than a lower floor once you've started. I'm still blocked from exchanging positions for my floors, they're always locked in place, clicking on the arrows does nothing. That's why, to create a lower floor, I had to fiddle with the elevations and height manually, and this is what resulted in not having enough space between the floors. |
| Posted by Gildaniel at Dec 13, 2019, 6:09:22 PM |
Re: Ceiling on lower floor overridden with floor on upper floor You can use arrows only to determine the sequence of levels with equal elevations It is not a problem to move new floor lower then the previous one, just change it's elevation. |
Current timezone is GMT Oct 13, 2026, 3:46:31 PM |
