Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Unusual item in 3D view |
| Print at Aug 28, 2026, 12:53:38 PM | |
| Posted by jjocsak at Dec 16, 2019, 12:55:02 PM |
Unusual item in 3D view This item is being displayed in my 3D view. When you rotate the image it goes away. When it's rendered it does not show up. Not a big deal just an annoyance. Any idea what it could be? https://drive.google.com/open?id=13AoDhKYmGW_ahYTKFJxNeNFtF-ELuN-o (You may have to copy/paste the link into your browser) Thanks Jeff |
| Posted by Puybaret at Dec 16, 2019, 4:58:39 PM |
Re: Unusual item in 3D view This is a part of wrongly computed ceiling, because you probably created a less high wall close to it. Don't display the ceiling of the room where it appears, or move the point of this room away from the small wall. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jjocsak at Dec 16, 2019, 7:26:53 PM |
Re: Unusual item in 3D view Not sure what wall is the problem. I deleted every wall individually to see which one was causing it and nothing fixed it. I stopped showing the ceiling in that room and that worked but I really want to find the problem. All walls are 8 feet. Thanks Jeff |
| Posted by jjocsak at Dec 16, 2019, 7:35:43 PM |
Re: Unusual item in 3D view I found the wall. It was the exterior angled wall on the lower floor. As soon as I deleted it the problem went away. Jeff |
Current timezone is GMT Aug 28, 2026, 12:53:38 PM |
