Print at Oct 8, 2026, 3:31:38 AM
Posted by bengillam at Dec 30, 2019, 6:36:27 PM
French window in alcove
Hi All,
I've been using SH3D on and off for a while and im trying to build up my house in sweet home 3d, we had a rough one before moving in but i would like to make one as accurate as possible for future home planning and decoration ideas etc.
On our back wall we have a french window which is set into a little alcove or recess (https://imgur.com/a/NlaC6Hz) see picture linked for example.
I'm not sure the best way to do this.
I tried making the walls that jut out shorter but this resulted in glitches in how it drew probably because this was wrong.
I then tried the guide using an invisible serving hatch, I end up having to make the whole back wall as thick as the depth of recess. I also seem to lose my floor texture which im not sure is right?
https://imgur.com/a/7Pdhp7X
https://imgur.com/a/s3p6qcO
Am i missing a trick here?
Any help would be appreciated.
THanks
Posted by VeroniQ at Dec 30, 2019, 11:49:30 PM
Re: French window in alcove
Did you try this tip ?
Hope it will help.
V
Posted by dorin at Dec 31, 2019, 7:01:30 AM
In my apartment all the doors and windows are in such position.
To solve this I modify PluginFurnitureCatalog.properties and add doorOrWindowWidthDepthDeformable#NN=false (where NN is the number of furniture).
Also, for some of them, I need to modify depth#, doorOrWindowWallThickness#, doorOrWindowWallDistance#
The result is something like this:
Posted by Cannoloz at Dec 31, 2019, 6:46:51 PM
Hope it will help.
V
Very nice tips, I did something close to the second for my windows but this is better.
Thank's!
