Print at Sep 23, 2026, 9:52:16 PM
Posts: 16   Pages: 2   [ Previous Page | 1 2 ]
Posted by dorin at Dec 19, 2021, 3:21:23 PM
Re: Rooms Information plug-in
New version 1.2.2
Bug fix (I hope) in use correct units on some languages, thanks to Aleksey Voitovich.
Also on SurceForge
Posted by dorin at Apr 6, 2022, 12:37:07 PM
New version 1.5
  • Fix an error when door or window are grouped.
  • Fix a bug in CSV export.
NOTE VERY IMPORTANT:
If You don't use yet Plugin Manager from Daniel118,
don't forget to remove manually the previous versions.
This one will don't replace it automatically!
The imported csv file could be look like this sample AFTER You format it in Office.
Also on SourceForge
Posted by dorin at Dec 7, 2023, 6:02:51 PM
New version 1.6
  • Fix a bug reported by Olivier when two or more levels have the same name sad but not all have rooms.
  • Probably I've made others bugs. Test it! (with care)
Also on SourceForge
Posted by goco at Jan 8, 2024, 5:58:14 PM
This from a user in the U.S. looking for totals in Sq Ft not meters: Your "Rooms Information plug-in" is absolutely GREAT!
Thanks so much,
goco
Posted by dorin at Jan 8, 2024, 8:26:59 PM
While I'm not a native English (also not a programmer) what I have to understand?
It worked or don't?
Anyway
1. Thanks you think it works (if this is the case)
2. Knowing my self I suggest you to verify it twice before fully trust the plugin results.
3. Try to find what don't work, let me know what and (with your help) I will tray to fix it.
Finally Manny thanks for your appreciations.
Posted by dorin at Jul 1, 2024, 10:22:17 AM
New version 1.7
- name spelling correction. Probably you will have to manually delete the old version.
- calculate only walls flush with the room(s)
- added room air volume column as @Robert Veres requested.
-- uses an average of wall heights around the room
- added a gray icon if the FlatLaf Dark theme is detected (byDMA wish)
- added pre-completed translation files for all available languages
Also on Source Forge
