Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: how to pierce a countertop in obj. |
| Print at Sep 30, 2026, 9:57:28 PM | |
| Posted by Superpippo at Jan 4, 2020, 3:13:29 PM |
how to pierce a countertop in obj. I need help. how to pierce a countertop in obj. with the spiral staircase? Thank you |
| Posted by hansmex at Jan 4, 2020, 5:13:08 PM |
Re: how to pierce a countertop in obj. If you design the counter top as a room, you can insert a staircase. Remove the staircase, then export and import the counter top for further use. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Superpippo at Jan 4, 2020, 5:40:36 PM |
Re: how to pierce a countertop in obj. thanks, but I don't understand. the ceiling is obviously pierced by the staircase ... but I imported a vaulted ceiling into the obj. that the staircase does not hole ... in practice I have to make the circular hole that connects the two floors on the obj. imported .... is it possible? |
| Posted by Superpippo at Jan 4, 2020, 5:49:17 PM |
Re: how to pierce a countertop in obj. in essence there is something similar to the "invisible box" that he uses on the walls, to hide a part of the obj. what am I using? |
Current timezone is GMT Sep 30, 2026, 9:57:28 PM |
