Print at Sep 24, 2026, 6:19:02 PM
Posted by 7rebel at Nov 2, 2008, 10:49:00 AM
Will not save...
I have the 1.4 version but i cannot get the program to save anything. When i click on "save" or "save as" it will highlight and then nothing happens. over an over again. When i close the program, it will ask me to save and with i click the save button, again nothing happens.
someone help!
thanks everyone.
[Note: this thread was started on sourceforge.net forums]
Posted by Puybaret at Nov 2, 2008, 1:15:00 PM
Re: Will not save...
What Java version do you use (see in About dialog) ?
I think it's a problem in Java. If you installed Sweet Home 3D with Java Web Start try to update the Java version installed on your system. If you installed Sweet Home 3D with the installer, try to update the Java version installed on your system and then use the Java Web Start version of Sweet Home 3D available at http://sweethome3d.sourceforge.net/download.html
See also: https://sourceforge.net/tracker/index.php?fun...id=152568&atid=784665
