Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Error message: "Can't print Home " |
| Print at Sep 28, 2026, 11:34:49 AM | |
| Posted by Loplop at Feb 1, 2020, 2:59:05 PM |
Error message: "Can't print Home "Hi everyone! I have a problem with the print area: when I go to print>create pdf or pdf preview, the message " Can't print Home" appears. Same if I go to Save as Post Script or send with mail. The message is the same with all the options I have in the pdf menu. I have a Mac but no problem at all with pdf in other softwares as Autocad or others. Could it be a bug with the Mac OS Catalina? Can anyone help me? Many thanks in advance!! |
| Posted by Puybaret at Feb 1, 2020, 3:33:34 PM |
Re: Error message: "Can't print Home " The last time someone reported me this error, he fixed it by updating the drivers of his printer. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Loplop at Feb 1, 2020, 10:34:27 PM |
Re: Error message: "Can't print Home " Hi Emmanuel, Thanks for your answer. I don't have any printer. I used to create a pdf and send it via mail. The problem is not linked with the fact of printing but with the creation of the pdf. The software don't let me create a pdf format. If someone has any idea... Thanks! |
| Posted by Puybaret at Feb 2, 2020, 6:22:40 PM |
Re: Error message: "Can't print Home " Strange... I just tried without any printer installed and it worked without problem. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Loplop at Feb 3, 2020, 11:22:53 AM |
Re: Error message: "Can't print Home " Any suggestion? Is there any settings I can adjust in the software or in my Mac? Do you think it can be liked with Catalina update? Thanks! |
| Posted by Puybaret at Feb 3, 2020, 6:31:43 PM |
Re: Error message: "Can't print Home " It's not a problem in Catalina, I tried it under Mojave and Catalina. The only suggestion that comes to my mind is to build your printed document yourself using other tools of Sweet Home 3D: - select the items in the furniture list and copy/paste them in a spreadsheet application like OpenOffice, - select all the plan and copy/paste it in Preview or any application able to handle images (why not OpenOffice again), - create a 3D image with the photo creation tool and include the generated image in the document you want to print. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mike603 at Sep 27, 2020, 5:16:20 AM |
Re: Error message: "Can't print Home "I am experiencing the same problem on a Windows machine. I have tried printing to 3 different printers so it's not a printer driver problem. I will reboot and try again. I am a paid user. |
| Posted by Puybaret at Sep 28, 2020, 8:39:08 PM |
Re: Error message: "Can't print Home " Did you try to print to PDF then print the generated PDF file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 11:34:49 AM |
