Print at Sep 26, 2026, 11:09:36 PM
Posted by Ninanoki at Feb 17, 2020, 7:53:59 PM
smile   Create a texture with different aspect ration
I try to import an image of a wooden decor by Egger. Here is a producer image: https://pasteboard.co/IV8ZUdb.jpg
wich is 600x360mm. While import the aspect ratio is incorrect, I can modify either width or height. Is there any way to have a correct texture?
Posted by hansmex at Feb 17, 2020, 10:06:59 PM
Re: Create a texture with different aspect ration
You should use an image editor to resize your image.
Posted by Ninanoki at Feb 17, 2020, 10:41:49 PM
resize to what dimension? such wooden decor is a rectangle, not square so I would crop it which I don't want to do.
