SH3D & Tools linux install & config -my way
This topic has been viewed 133525 times and has 15 replies
Questions about Sweet Home 3D installation [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Re: SH3D & Tools linux install & config -my way
Post by dorin »
I've don't test it BUT
on SweetHome3D file, at the end, is -open "$1"
Why? I don't know. You could try.
Post by Keet »
Now that worked! Apparently the full filename is the second item in the argument list ($0=first, $1=second argument).
Post by dorin »
Thanks to lighten me! [=D>]
otadmin
Post by otadmin »
Worked for me by installing openjdk from the linux repositories.
RealBLAlley
Country: USA
Post by RealBLAlley »
Nope. Black interface and no idea what you're referring to with the "editors" jar files.
Post by dorin »
If I've correctly understand you want to move(copy) a Windows installation to an linux system.
1. Make a copy of Windows installation to an usb stick(fat32).
Probably C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D or similar
2. Start linux system, download the official version NOT the repository version.
3. Extract SweetHome3D-7.5-linux-x64.tgz. Will result a new folder SweetHome3D-7.5.
4. In this folder double-click on SweetHome3D file. If prompted to choose if to execute it, answer YES. The program start.
5. Go to settings and make some necessary changes and save it and close SH3D.
This will create all you need under /home/[user_name]/.eteks/sweethome3d/
6. Copy your saved files from usb stick into corresponding folders.
Restart SH3D.
PS1 The editors jar files is refer to Furniture[Texture]Editor.
PS2 Don't be so impatient. Sometimes(I don't know why) especially the new users, have to wait until their post will appear in the forum.
I've encountered the same problem at the beginning.
