In case a search also leads someone else here looking for an answer to 'How do I reset the wall colour back to default?'. My work around is to click the 'Texture' button (but don't set any texture) and then 'OK'.At this time, you can remove color only with an undo operation.
But the default color is just white with a dark grey ambiant color. If you choose a grey color, you should obtain the same effect.
How to color walls?
This topic has been viewed 27133 times and has 10 replies
Re: How to color walls?
