Door Frames
This topic has been viewed 14721 times and has 12 replies
Looking for a particular 3D model or texture? [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
snmavronis
Country: USA
Re: Door Frames
Post by snmavronis »
I figured it out! Lots of trial and error understanding how the SVG parameters interact.
My finial custom SVG cutout shape:
M0,0.0505 a0.83, 0.25 0 0,1 1, 0 v0.9495 h-1 z
Steve N Mavronis - Retired PC Tech
Country: Paris, France
Re: Door Frames
Post by Puybaret »
Nice try, congratulations!
But... I wonder if the ghosting effect you got in the rendering would be due to the fact that you didn't change the color of both sides of the wall you exported.
I don't get this effect in the example I posted...
snmavronis
Country: USA
Re: Door Frames
Hmm right I only colored one side. I should test that out using the test room I made. The bad thing is even with my walls 1/8” thick would it cast a shadow on the floor even though being set to transparent?
Oh well, at least I used some SVG and learned something new because I was so curious how the 3-sided door frames did their magic with no threshold bottom side. Custom partial arcs at the top are tricky to figure out.
Users browsing this forum: Amazon [Bot]
