Photo creation problem
This topic has been viewed 20299 times and has 14 replies
Country: Paris, France
Re: Photo creation problem
Post by Puybaret »
Once photo creation is started, Sweet Home 3D doesn't use tmp disk space (it may require swap space because it grows in memory but swap is managed by the system).
Please, post here the Console messages if you can ; it will give me really some information.
Post by Puybaret »
I discovered with a French user that photo rendering may fail if two walls are superimposed on each other. Please, check whether it's your configuration or not.
LUH3417
Country: Hofstetten, Zürich, Schweiz
Post by LUH3417 »
I have the same problem underWin XP. Sometime a restart will help.
But now with a scene with many objects rendering/photo does not work at all. I tried to find console program but I can't find it. There is no application directory.
best reagrds lucas
kamilamonica
Country: Poland
Post by kamilamonica »
Hi there!
I made a new project with no furnitures at all, just windows (only one in the photo to be created) and the rendering still failed. It fails in two fashions; one of them while working, with red or green squares displayed as before, or in the other style, showing a red 'x' like the image was missing.
Thanks!
From Puybaret
Please try this:
1. Launch Console program found in /Applications/Utilities folder and click on Clear display.
2. Launch Sweet Home 3D and try to create a photo.
3. Console program should display some new text that will help me a lot to guess your issue. Please select that text and copy paste it in a comment here.
Hi Puybaret,
Here you are, the errors:
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] Exception in thread "Thread-7"
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] java.lang.ArrayIndexOutOfBoundsException: 64
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.accel.BoundingIntervalHierarchy.intersect(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.trace(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceReflection(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceReflection(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.ShinyDiffuseShader.getRadiance(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.getRadiance(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.getRadiance(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.computeSubPixel(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.refineSamples(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.renderBucket(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.access$300(Unknown Source)
10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer$BucketThread.run(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] Exception in thread "Thread-6" java.lang.ArrayIndexOutOfBoundsException: 64
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.accel.BoundingIntervalHierarchy.intersect(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.trace(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceReflection(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceReflection(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.ShinyDiffuseShader.getRadiance(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.shadeHit(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceRefraction(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceRefraction(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.getRadiance(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.getRadiance(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.computeSubPixel(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.refineSamples(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.renderBucket(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.access$300(Unknown Source)
10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer$BucketThread.run(Unknown Source)
Does anyone know how to avoid this issue? To me it looks like the error is given by 3D models downloaded from unknown sources.
Regards
Kamila
Post by Puybaret »
For information, this bug was fixed in version 2.6.
