My own home (as is)
This topic has been viewed 52792 times and has 13 replies
NIMAN
Country: United Kingdom
Re: My own home (as is)
Post by NIMAN »
I think I can still imagine how tabbing through the levels could, sometimes, be useful, if it was available, though.
Not currently sure how this was designed to work.
Anyway, if someone knows it is a bug and comments then i'll report it.
This shortcut list (excellent work by Véronique [Updated on July 17, 2022]): (http://www.sweethome3d.com/blog/2019/03 ... tcuts.html)
states:
Windows/Linux/Mac
Action
Select a level in a plan
Keyboard shortcut
Arrows ← → with the focus on tabs
Actual behaviour in SH3D (7.2) on Win 7&10:
Clicking on a level tab followed by a keyboard arrow key does not appear to do anything.
Double clicking on a level tab (obviously) displays the "Modify level" dialog. When any of "close/ok/cancel" in that dialog are then pressed and, subsequently, a left/right keyboard arrow is pressed then the other levels (but only those displayed on the same line as the level originally chosen) are stepped through.
As a note:
double clicking to activate the behaviour is inconvenient
stepping through a single line of displayed levels only makes the functionality very limited (for my use case, useless).
sjb007
Post by sjb007 »
NIMAN, I can't test in Windows right now, but I see the same behaviour in Linux. The issue seems to be that on a single-click tab change the 2D plan area is auto focused. What you can do is when the 2D plan has the focus, use Shift-Tab to move the focus to the tabs, then use left/right arrows.
Next, if you have so many levels that you have more than a single row, you can use the up/down arrows to rotate through the rows as well.
NIMAN
Post by NIMAN »
Nice one sjb007 - that all works here too.
Not the automatic "raster scan" type effect I first expected/hoped for but could definitely be useful.
Thanks.
jaffar34
Country: Pakistan
Post by jaffar34 »
This is an excellent approach to home remodeling! Using Sweet Home 3D helps visualize every detail before starting real work, ensuring time and cost efficiency. Pairing such planning with Bridging Finance can provide the necessary short-term funds to complete the project smoothly without financial strain. Combining smart design tools and strategic financing ensures a seamless renovation journey from concept to completion. https://bridgingfinance4u.co.uk/
