Sketch-A-Graph type of hinge deformation
This topic has been viewed 6523 times and has 11 replies
Daniels118
Country: Italy
Re: Sketch-A-Graph type of hinge deformation
Post by Daniels118 »
You forgot the "sweethome3d_" keyword after "_and_". For example:
Code: Select all
g sweethome3d_hinge_4_and_opening_on_rail_3_bottom_96_9_9_9_9_164_165_166_166_444_443_668
should be:
Code: Select all
g sweethome3d_hinge_4_and_sweethome3d_opening_on_rail_3_bottom_96_9_9_9_9_164_165_166_166_444_443_668
Here the fixed model.
Post by Keet »
Code: Select all
should be:
Code: Select all
After creating the Murphy Bed I figured it would have to be something like that. I found that sometimes the 'd' on my keyboard fails to accept the keypress so I thought that would be the problem but I managed to forget the 'sweethome3d_' part there too once or twice before everything worked [:(]
Thank you for fixing the model so I won't have to go through it again!
