Measuring a multipart distance?
This topic has been viewed 11888 times and has 22 replies
decard
Country: AU
Re: Measuring a multipart distance?
Post by decard »
hmmm. so i could create a dummy Room (i wish this function had a more suitable name), and check there.
i wil try that too. Thank you.
decard
Country: AU
Post by decard »
thank you.
not fully cognisant at the moment of all that you refer to, but will check more in coming days
decard
Country: AU
Post by decard »
hi.
certainly measuring (or displaying) total length of polyline would seem to be a useful worthwhile thig to have
and should be embedded as function of polyline itself, rather than separate Dimensions function.
Daniels118
Country: Italy
Post by Daniels118 »
@Decard
I'm not sure if your message is in reply to mine, in such case the Wirings toolbox displays the lenghts grouped by line style/color, so you can use a different color/style for each measurement. The real purpose is to measure how much wire to buy, provided that different parts of the electrical plant may require different kind of wire.
Si60
Country: Vanuatu
Post by Si60 »
Looking at thus post has reminded me of another matter I have been considering.
Is it possible to auto dimension walls in elevation or 3D view?
Or even manually dimension?
I think that this feature would be very useful.
Presently I am building a house I have designed on SH, but I find I have to manually (and time consumingly!) draw the wall elevations, using 'properties' of things like windows and doors, to be able to set up the formwork.
As someone else has suggested, the wiring plug-in sort of works. It also suggests that the program 'knows' what the dimensions are, there just needs to be a plug-in or whatever to reveal that information.
Lastly many many thanks to all the clever people who have contributed to the development of this amazing software. Personally I wouldn't even know where to start!
Daniels118
Country: Italy
@Si60
Maybe the 3D dimension lines plugin could work for you.
Please open a new thread if you need to continue the discussion.
Post by hansmex »
After reading your last message, I installed Pan3D and Dimensions3D.
I then tried to make a render to see whether the dimensions show up in the images.
Unfortunately, no matter what I tried, I wasn't able to produce an image. Not with SH3D, nor with any of the rendering plugins from Enko.
After uninstalling both plugins, I as able to make renders again.
Contact me in private if you need more info, such as complete list of installed plugins.
decard
Country: AU
Post by decard »
@Decard
many thanks for this.
for my trivial excecise (Kitchen Triangle), i just used three p-to-p Dimensions
but this plugin is a very useful plug-in any case, which i must keep in mind for the purpose for which it was intended. or any other multi-point measurements.
decard
Country: AU
Post by decard »
In Google Maps it is possible to make a multi-point measurement. Even to the point that when the last click is on the same position as the first click, GM also gives the enclosed surface.
SH3D doesn't have either of these functions.
hmm. you give me idea for something completely different! :-)
just recently, i was trying to measure how far i am running at the moment (i recently started again after 30 years), and you are right i think - i could use Google Maps to calculate. i use, but i never thought of that purpose.
decard
Country: AU
Post by decard »
have now checked/trioed this (Google Maps) fopr my running distance.
works well once you get te hang of it. the only prob is - a limit of just 10 data points. which was JUST enough for my current run, but not enough for planned run/s.
(btw, it seems to be accurate as it almost exactly matched what we measured on bike - which sort of confirms the accuracy of both.)
but having been given that idea, might search if i can do with something woith more data points
Users browsing this forum: Amazon [Bot]
