confused higher stuff obscured by lower stuff
This topic has been viewed 5645 times and has 12 replies
Re: higher stuff obscured by lower stuff
Post by Keet »
... I created what will be a physical wall inside the regular room walls (using several box objects for the various components) so that I could plan the placement of studs, plates, and sheetrock along one side of a staircase in my basement. In carpentry a plate is a 2x4 or larger length of wood that's laid horizontally on its side at the bottom and top of a wall. The vertical studs go between them and connect them...
You might be interested in the Dimensional Lumber library that offers lumber objects for that sort of construction.
DaveLab
Country: United States
Post by DaveLab »
Good thought. Lemme give that a go. Thanks!
DaveLab
Somewhere in western Massachusetts
DaveLab
Post by DaveLab »
My last reply was for the grouping suggestion. As for the dimensional lumber library: wow. Can't wait to check that out. Thanks. :)
DaveLab
Users browsing this forum: Baidu [Spider]
