Sweet Home 3D 7.2
This topic has been viewed 286133 times and has 90 replies
Re: Sweet Home 3D 7.2
The art of using your vacation to benefit the community. Thank you Emmanuel for this version; it's a real treat in the middle of summer.
Hi, noticed that the path in the video window is no longer shown when you create a video.
Thanks for your nice comments [:)]
The video path is back in the version Beta 4 (see updated links in the first post of this thread).
This version fixes also the list of printed furniture when levels are selected in the page setup dialog box, and adds a few more preset shapes for the mannequin of the default catalog.
crackwood01
- Member
- Country: Canada
Pardon my ignorance, but i've downloaded the 7.2 Beta 2 file for windows.
After my installation i have a (no plugin 7.2 version) and another 7.1.1 version with plugins installed.
how can i install plugins in 7.2
p.s. my 7.1.1 is a piad version from the microsoft store
- GaudiGalopin3324
- Advanced Member
- Country: Russia
Thank you Emmanuel. Translucent models are perfectly obtained in the Yafaray version. There are a lot of possibilities now.
I'm not sure if it's related to the new version...
When I make a staircase, I can't modify it anymore.
I tried several formats of staircase, in existing or new/blank instance of SH3D, but the result is the same. I can generate the staircase, and in the right-click pop-up menu Modify Furniture is available, but nothing happens. Same result when double-clicking the generated staircase.
I have sent the file to your email.
Thanks for your reports.
The bug reported by Hans is fixed in the version 7.2 Beta 5, and can be tested with the updated download links in the first post of this thread.
This update fixes also some bugs in the modification of multiple dimension lines and comes with a version of JOGL updated to v2.5.0-rc-20230813.
crackwood01, I thought that the free version and Windows Store version shared the same private data folders but it doesn't seem to be always the case...
You can find their location by clicking on the links showed in the Libraries in use pane, displayed by clicking on the Libraries... button at bottom of About dialog box. If this button is missing, just install a furniture library.
Thank you very much for your super fast solution. Will test it tomorrow.
Nice improvements!
Wouldn't the changes to dimension lines (elevation) also not make it easy to create 3 dimensional poylines (i.e. adding elevation to each of the polyline points). Guess that would also make the 3D-wiring plugin much simpler and beter integrated with the core SH3D.
Polylines and dimensions are handled differently in 3D: polylines have a variable width in 2D and dash style, but no thickness in 3D, whereas dimensions are lines of fixed thickness with no dash, much more simple and faster to draw!
