Door with two different sides
This topic has been viewed 9168 times and has 11 replies
Looking for a particular 3D model or texture? [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Re: Door with two different sides
Post by Keet »
Well, that model was a mess. I decided to create a completely new model similar to your example. I have added it to my DodecagonDoors furniture library. Using the library has the advantage that sashes are shown in the 2D plan and the model has nice borders that extend outside the wall. Without a library you can't get that.
The door is created for a wall with a 20cm thickness and of course the door opens. You can change a multitude of materials for different parts of the sides and the door, both for inside and outside (27 material names). And while it is more detailed it is less than half the object size of the example [:)]
You can download the library from dodecagon.nl/dodecagondoors.
efall1
Country: United States
Post by efall1 »
Okay, so it wasn't just me struggling with that other model!
Thank you so much!!! This is perfect and exactly what I was looking for. You're the real MVP! [:x]
