I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception
This topic has been viewed 16452 times and has 14 replies
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
angeliclayer
Country: London, United Kingdom
Re: I Compiled Sweet Home 3d and when i excecute the jar file its give a Java Exception
Post by angeliclayer »
Does anyone have definitive steps for this? I'm experiencing the build fail issue same as chicosRV. If I follow the steps above, I do not see an option to select the JDK instead of JRE.
I'm using Eclipse version 4.2 and Eclipse Java Development Tools 3.8.2.
Thanks in advance for any advice on this matter.
Country: Paris, France
Post by Puybaret »
In the JRE tab of Ant configuration, click on Install JREs and add a JVM which root directory matches a JDK installed on your computer.
angeliclayer
Thank you so much! I have solved it now. It was for a very final year project so I'm very thankful for the fast response. :)
Post by Puybaret »
Great you could make it. [:)]
Would it be possible that you share with the community what your project was about?
angeliclayer
Sure! I'm doing my dissertation about this software to help Occupational Therapy patients during the pre-discharge home visit assessment.
I'm currently just improving on someone else's plugin but also needed to improve on some of the UI to allow for people who aren't very dexterous to be able to use the software. I have also tried adding the to the furniture catalogue a few occupational therapy items by default. I'm currently unable to share this at the moment because the plug-in (other than the changes I've made) isn't mine but I'll gladly share what I've coded myself (after I've submitted my work) :D
