day or night image
This topic has been viewed 7136 times and has 16 replies
Re: text on walls
Hi lately very busy . i still can not write text on wall . or i think i am not giving more information what i am trying to say, so i have a wall create in sh3d then give some colors , some people hanged there image or pictures , but simply want to write on it .then want to copy as a new furniture then export to obj format , so then i can use it many time as i wish , i hope not asking too much
Re: text on walls
There's no direct way to write a text on the wall. As Hans partly suggested, a workaround is to create an image containing that text (eventually with a transparent background), import that image in the program as a texture, and apply that texture on a thin box.
Of course, if you have to do that many times, it will become tedious and Sweet Home 3D might not be the right solution for you.
Re: text on walls
So back again . ?: If i have a pic or jpg or any type format how can i add to my furniture or as a object 3d still not understanding how this program works , in furniture import wizard only you can chose between obj,dae 3ds,lws,zip. but no jpg file , is there any one tell me what should i do thanks in regards
Re: text on walls
Ok if so
then tell me how can i add frame made by any picture or photo as , or my photo taken by camera to hanged in living room or bedroom
Re: text on walls
HI there must be a way to add 2D models import like 3D models import
Re: text on walls
As said previously, import the image containing your text in the program as a texture, and apply that texture on a thin box (found in Miscellaneous category).
Re: text on walls
hi as you say ,import the image containing your text in the program as a texture, and apply that texture on a thin box,, how is there any pdf file to understand , i have import jpg file but not found any where , its vanished
