Problem Starting Online Version
This topic has been viewed 22195 times and has 22 replies
Questions about Sweet Home 3D installation [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
StNff
Re: <font><font class=""> Re: Проблема Начиная Электронная версия </font></font>
Post by StNff »
I'm sorry, all my fault my English, and lack of knowledge about programming.
I constantly have to use the Google translator.
I have a successful build.
But the error is still there (ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet).
Could this error cause,
[javac] D:\1\build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
alse for repeatable builds?
Country: Paris, France
Post by Puybaret »
The ClassNotFoundException means Java didn't find the class, i.e. it wasn't in the jar files you gave, or the jar files are not found.
StNff
Post by StNff »
I had a warning:
<b>build.xml:43: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds</b>
So I decided to try Ant 1.7, building failed. I decided to try Ant 1.9 - building successful, but I still have the error ClassNotFoundException com.eteks.sweethome3d.applet.SweetHome3DApplet.
I see no error in the log that generates this error. You may have a different opinion. I therefore complete log.
<b>D:\1>ant javaWebStart
Buildfile: build.xml
build:
[mkdir] Created dir: D:\1\build\classes
[javac] Compiling 2 source files to D:\1\build\classes
[javac] Compiling 193 source files to D:\1\build\classes
[javac] Note: D:\1\src\com\eteks\sweethome3d\swing\JPEGImagesToVideo.java uses or overrides a deprecated API.
[javac] Note: Recompile with -Xlint:deprecation for details.
[javac] Note: Some input files use unchecked or unsafe operations.
[javac] Note: Recompile with -Xlint:unchecked for details.
[copy] Copying 261 files to D:\1\build\classes
[zip] Building zip: D:\1\build\SweetHome3D.jar
[delete] Deleting directory D:\1\build\classes
application:
[zip] Building zip: D:\1\build\SweetHome3DStandalone.jar
[move] Moving 1 file to D:\1\build
furniture:
[zip] Building zip: D:\1\build\Furniture.jar
textures:
[zip] Building zip: D:\1\build\Textures.jar
help:
[zip] Building zip: D:\1\build\Help.jar
jogl-java3d:
[zip] Building zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar
BUILD FAILED
D:\1\build.xml:118: Problem creating zip: D:\1\build\macosx\java3d-1.6\jogl-java3d.jar (╤шёЄхьх эх єфрхЄё  эрщЄш єърчрээ
√щ яєЄ№) (and the archive is probably corrupt but I could not delete it)
Total time: 1 minute 13 seconds
Buildfile: D:\1\build.xml
build:
[javac] D:\1\build.xml:46: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to f
application:
furniture:
textures:
help:
jogl-java3d:
java3dLibraries:
[zip] Building zip: D:\1\deploy\lib\macosx\java3d.jar
javaWebStart:
[mkdir] Created dir: D:\1\build\JNLP-INF
[copy] Copying 1 file to D:\1\build\JNLP-INF
[zip] Building zip: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar
[zip] Building zip: D:\1\deploy\lib\SweetHome3D.jar
[input] Enter Passphrase for keystore:
111111
[signjar] Signing JAR: D:\1\deploy\lib\Loader3DS1_2u.jar to D:\1\deploy\lib\Loader3DS1_2u.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] The signer certificate will expire within six months.
[signjar] Signing JAR: D:\1\deploy\lib\SweetHome3D.jar to D:\1\deploy\lib\SweetHome3D.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\SweetHome3DJavaWebStartBootstrap.jar to D:\1\deploy\lib\SweetHome3DJavaWebStart
Bootstrap.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\batik-svgpathparser-1.7.jar to D:\1\deploy\lib\batik-svgpathparser-1.7.jar as S
weetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\freehep-vectorgraphics-svg-2.1.1.jar to D:\1\deploy\lib\freehep-vectorgraphics-
svg-2.1.1.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\iText-2.1.7.jar to D:\1\deploy\lib\iText-2.1.7.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\jmf.jar to D:\1\deploy\lib\jmf.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\linux\i386\java3d.jar to D:\1\deploy\lib\linux\i386\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\linux\x64\java3d.jar to D:\1\deploy\lib\linux\x64\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\macosx\java3d.jar to D:\1\deploy\lib\macosx\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\sunflow-0.07.3g.jar to D:\1\deploy\lib\sunflow-0.07.3g.jar as SweetHome3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\windows\i386\java3d.jar to D:\1\deploy\lib\windows\i386\java3d.jar as SweetHome
3D
[signjar]
[signjar] Warning:
[signjar] Signing JAR: D:\1\deploy\lib\windows\x64\java3d.jar to D:\1\deploy\lib\windows\x64\java3d.jar as SweetHome3D
[signjar]
[signjar] Warning:
[echo] deploy dir ready for ftp
BUILD SUCCESSFUL
Total time: 2 minutes 56 seconds</b>
Post by Puybaret »
Forget warnings, it's not the problem.
StNff
Post by StNff »
My "SweetHome3DApplet.html" has an entry:
var jars = "lib/SweetHome3DApplet.jar,lib/Loader3DS1_2u.jar,lib/batik-svgpathparser-1.7.jar,lib/jnlp.jar"
But the directory does not contain SweetHome3DApplet.jar
In the folder there SweetHome3D.jar, all right?
Post by Puybaret »
How do you think it could work if you provide SweetHome3D.jar when the applet expects a SweetHome3DApplet.jar file??? I fear you mix up some concepts and try to run an application as an applet, but it won't work this way. [:(]
Applets and Java applications are not the same even if they can share some classes. Spending more time on learning about applets might help.
StNff
Post by StNff »
Then please tell me where to get this jar file and why it is missing after a successful build.
Post by Puybaret »
Run "ant applet"
StNff
Post by StNff »
Thank you very much! You have given me great help! This morning, studying build.xml I myself realized that asking the wrong target when building. Read your reply and smiled my carelessness. Everything works. However, the program has a red body instead of models, there is no icon. I set the parameters as follows:
furnitureCatalogURLs:"catalog/furnitureCatalog.zip,lib/additionalFurnitureCatalog.zip",
furnitureResourcesURLBase:"catalog/models/",
texturesCatalogURLs:"catalog/texturesCatalog.zip",
texturesResourcesURLBase:"catalog/textures/".
I will study the materiel on.
StNff
Post by StNff »
Have you encountered such a problem? On some computers do not display a tree of elements and textures, on the other they are available. In what could be the problem? In the version of browser?
