sad High priority Using Sweet Home 3D in Eclipse
This topic has been viewed 12446 times and has 14 replies
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Gforce85
Re: Using Sweet Home 3D in Eclipse
Post by Gforce85 »
By the way my java runtime library is in the following path:
C:\Program Files (x86)\Java\jre7\bin
Maybe I Should add the java 3d dll files in this 'bin' folder and point to this folder from the VM option like this ?:
-Djava.library.path=C:\Program Files (x86)\Java\jre7\bin
binadnsh77
Post by binadnsh77 »
I think it does not work in i386 window systems. It works fine in Linux-32 bit and windows 64 bit. I have tried it.
Country: Paris, France
Post by Puybaret »
I think Gforce85 and you mixed so much things in the DLLs and the PATH of your Windows computer that it's too difficult to help you without being in front of it.
Gforce85
Post by Gforce85 »
It works now with the windows 64 bit version!:
My installation dir is:
D:\Open Source\Sweet home 3D 27-3-2013\SweetHome3D-4.0-src
And in eclipse at the run configuration menu I have this in the VM arguments:
-Djava.ext.dirs=lib/windows/x64;lib
binadnsh77
I installed Java3D in my Windows 32 bit system and then I was able to run the sweethome3d from eclipse. Since I had installed the Java3D there was no need to pass the VM arguments.
