Installation OK Cannot Save
This topic has been viewed 12856 times and has 20 replies
Questions about Sweet Home 3D installation [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Country: Paris, France
Re: Installation OK Cannot Save
Post by Puybaret »
By the way, you didn't need to install Java. The installer version of Sweet Home 3D comes with its own private copy of Java (it's in the jre6 subfolder of the installation folder of Sweet Home 3D).
Post by Puybaret »
Stupid questions:
Is you disk full?
Can you save a document with other software?
RicReeves
Post by RicReeves »
37GB free
Do I need Java 6 installed?
I downloaded Java 7 Update 21 from the Oracle site and installed that...
Post by Puybaret »
As said previously, you don't need to install Java, but I don't think that removing Java will solve your issue.
RicReeves
Post by RicReeves »
I only installed Java because I thought the lack of Java was causing the error!
I have uninstalled Java, and Sweet Home, restarted and reinstalled. Still can't save.
Have tried the same but running the installer as Administrator, still no change.
RicReeves
Post by RicReeves »
Any further thoughts?
The software is great, I just don't want to involve myself in anything, if I can't subsequently save it!!
Thanks
Post by Puybaret »
No idea at the moment. Never heard about this case, and really don't understand why you couldn't save.
Meanwhile, you can still use the Online version which proposes the same features, except you can't import as much 3D models as you want. If you can't export the SH3D file of your project too, I'll send it to you by email.
Post by Puybaret »
A new idea: did you try to open an existing .sh3d file of the gallery, then save it?
RicReeves
Post by RicReeves »
It worked!
Downloaded the example. Opened it, saved it (took about 3 minutes to save).
Created a new file and it saved fine!!
Thnk you for your help Emmanuel! I look forward to using the software!
MajRose
Post by MajRose »
I'm getting the same error and I have done nothing different to the file. I have the up to date version of Java and SweetHome 3D. I have no clue what to do!!!
