Aaargh!
The panel loses its transparency after rendering. Or it acts real weird, half transparent or something.
There was a 'glass box' model I had before but can't find it.
Any other glass objects I could use?
Thanks.
Modernist / minimalist windows, doors, frames?
This topic has been viewed 9976 times and has 16 replies
Re: Modernist / minimalist windows, doors, frames?
Fatal rendering error?
Sorry for all the questions lol.
The glass box will only create a hole in the wall if it's at least as deep as the wall? Leaves me with glass as thick as 30 cm.
The pane doesn't need to be as thick in order to create a hole in the wall. So I guess all I need is a good glass pane that doesn't act up after rendering.
Thanks.
Am I importing them the wrong way?
Boxes seem to need to be as deep / thick as the wall I place them in before it will create a hole, the glass pane (doesn't render) I used before didn't.
Ok, i think this is working:
Wall.
Place invisible box inside wall, this creates a hole.
Place glass box / pane inside hole.
Wall.
