sad Version 5.1 doesn't work in windows10, but version 5.0 does
This topic has been viewed 20294 times and has 12 replies
Questions about Sweet Home 3D installation [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Country: Paris, France
Re: Version 5.1 doesn't work in windows10, but version 5.0 does
Post by Puybaret »
After a request to the company that issued the certificate used to signed Sweet Home 3D, it seems the problem could be bound to the fact that this certificate uses SHA-1 and not SHA-2.
As said previously, this doesn't make the program corrupted though.
I'm going to request a SHA-2 certificate that I'll use to sign the next version.
stefbu
Post by stefbu »
same problem even with version 5.2.
Work only version 5
Post by Puybaret »
To those of you who had some problems with versions 5.1 or 5.2 last year, could you test again whether Sweet Home 3D 5.2 still crashes, then try the behavior of the version 5.5 beta 11. If the Beta version doesn't crash anymore, that will mean that the issue in Java 8 will have been fixed.
Thanks for your help and feedback! [:)]
