sad Fatal error at starting : need to updated drivers opengl directX
This topic has been viewed 32499 times and has 18 replies
wannerb21
Country: Australia
Re: Fatal error at starting : need to updated drivers opengl directX
Post by wannerb21 »
I downloaded the program on a windows 7 ultimate (TRAVELING so use the old trusty laptop)
Worked fine and allowed me to save the 3D pictures and even allowed me to edit the 3D pics in the initial session. When I went to reopen them for a second session the fatal error message closed the program down.
I downloaded the drivers, but no luck. Seems strange that it all worked perfectly when the program was first installed.
Post by bdfd »
Can you verify the version of java ?
[email protected]
Country: Pakistan
Post by [email protected] »
Is there any solution of this drivers problem???
Country: Paris, France
Post by Puybaret »
Sorry but I fear there will be never a universal solution for drivers. Sometimes, a system update breaks something, sometimes a driver update breaks something else.
Nitemare
Country: Murcia, Murcia, Spain
Post by Nitemare »
pooky2483
Country: DERBY, Derbyshire, UK
Post by pooky2483 »
Well, as of 11 Dec 2019 the problem still exists.
I'm running Kubuntu16.04LTS
OpenGL Version 3.0 Mesa 18.0.5
phpworm
Country: United States
Post by phpworm »
I'm having the same issue as of 3 March 2020
Linux Mint 17
OpenGL version 4.5.0 NVIDIA 384.130
I can run the older version available through the package manager without any problems, but the downloaded current version tells me to update my drivers even though I'm using the recommended drivers.
Is there no solution for this?
phpworm
Post by phpworm »
UPDATE: I feel pretty stupid but after running the file named "SweetHome3D-Java3D-1_5_2" instead of "SweetHome3D" it is working, and appears to be the current version. It was just the filename throwing me off.
mmanzur
Country: Chile
Post by mmanzur »
Have the same problem in 64 bits version. I install the 32 bit versions and the problem has gone [:)]
Users browsing this forum: Amazon [Bot]
