SweetHome3D On Surface Book Hi Res Display
This topic has been viewed 13264 times and has 13 replies
Discuss anything here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Slate
Re: SweetHome3D On Surface Book Hi Res Display
Post by Slate »
Hello I also have a Microsoft Surface Book with 3000x2000 display and I'm not having any luck getting the display to look decent. It seems no matter what I try I still have a truncated left menu in Sweet Home 3D.
I've tried both the Windows 5.5.2 version and adding an ini file with 1 line or the 5 lines of code mentioned here to no avail, and the Java Web Start 5.5.2 version.
Any thoughts?
Country: Paris, France
Post by Puybaret »
Are you sure the .ini file doesn't have an additional .txt extension?
Slate
Post by Slate »
Arg you're absolutely right, I recently switched computers and I didn't realize the option to view file extensions was still turned off so the file was actually showing .ini.txt instead of just .ini. Many thanks for your spot-on reply!
Post by Puybaret »
Thanks for your feedback [:)]
I feared that the solution I programmed didn't work anymore on some configurations...
