Azure Home
This topic has been viewed 86184 times and has 29 replies
Re: Azure Home
Post by bdfd »
I like very much the idea for the office! Also the other one.
TY.
Should I leave the door for the office near the stairs, once entering the house, or should I remove it and leave only the access through the living room?
Imho I should leave the door :).
For practicity, let the door if not you should do all the round to go to the entry.
In the same style, you can put a sliding glassed door between office and living room like this :
Country: UK
Re: Azure Home
Post by Mike53 »
Love the colors used on this project, would be nice set overlooking a beach.
One thing i noticed on the plan, i am not sure about the regulations in Italy, but in the UK you cannot have the top of the stairs that close to a door.
Re: Azure Home
Post by bdfd »
No problem for this in France ! [;)]
AdeleAlli
Country: Italy
Re: Azure Home
Post by AdeleAlli »
Thank you Mike, sooner I will try to put a beach overlooking.
I do not know the regulations here in Italy, but for now the house is only a virtual project, if someone will decide to build you I will get some info about it :).
Unfortunately now I am preparing some exams so I have not time to dedicate to this project but I after this session I will start working on the interiors :).
AdeleAlli
Country: Italy
Re: Azure Home
Post by AdeleAlli »
Hi, I tried to realize this rendering, at 7 AM, a morning view of the background of the house...
AdeleAlli
Country: Italy
Re: Azure Home
Post by AdeleAlli »
I think that maybe the background is wrong for a morning view. Here is a tentative to make it better:
Here the sun is behind the house so everything is in shadow, but the idea was exactly that, simulate the morning sun.
Country: Copenhagen, Denmark
Re: Azure Home
Post by Ceciliabr »
Beautiful renderings!
You are creating very nice moods.
___
You could try scaling down the height of your sky images so you get the clouds closer to the horizon – and see what happens :)
And to make the snapshot absolutely perfect, you should turn the compass a bit, so that the shadows of the sun matches the sky image.
AdeleAlli
Country: Italy
Re: Azure Home
Post by AdeleAlli »
___
Thank you for the suggestions Cec, I need to take confidence with the sh3d way of managing the background image.
For now, I tried to use the advanced rendering plugin (I was able to make it work). The image I posted some time ago was this one:
Using the plugin I realized this one:
I think the colors and shadows are better, and the overall quality of the rendering is better, it is not perfect because I do not play as required in order to find the best lights. I am only at the beginning with this plugin but I think there are great possibilities to realize great renderings. I will be happy if I could realize closed to reality renderings as those seen by you or other sh3d users that posted into Gallery.
This is another result:
Re: Azure Home
Post by okh »
..you should turn the compass a bit...
@cec As an amateur navigator, I object! I have met women who wanted the Earth to move, but a compass is not the best way. You should adjust the date/time - and if it still does not fit, you need to shift the background image... [:)]
@AdeleAlli: Great renerings. Love the feel you created. Speaking of the compass, where is this?
(Just back from Sardinia...)
AdeleAlli
Country: Italy
Re: Azure Home
Post by AdeleAlli »
It is hard to find the exact and perfect position of everything in order to create realistic atmospheres, but I will try (maybe after September 14th, because I should study for an exam XD).
I love this software and I want to be able to create perfect or almost perfect renderings so usually I fail in studying and then I play with sh3d XD.
Thank you okh.
Somewhere in south Italy, maybe near Catanzaro (Calabria), I saw many villas that I appreciated and this is inspired by one of those.
Adele
