big grin High priority Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)
This topic has been viewed 14237 times and has 17 replies
Features you would like to see [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
YGYL
Re: Pre-segmented dynamic object system!!!! (Automatically generate stretched objects)
Post by YGYL »
Pre-segmented dynamic object system is like this GIF picture.
gif file
YGYL
Water pipes and electric wires
Post by YGYL »
Download the file
Water_pipes_and_electric_wires.sh3d
2D
vertical 2D view
3D view
3D detail
Re: Water pipes and electric wires
Post by bdfd »
Good idea !
In France, all electric network is in the ceiling.
It's easier to access and it avoids flooding … [;)]
YGYL
Woods and grass
Post by YGYL »
Woods and grass
Download the file
Woods_and_grass.sh3d
2762 grass objects with different directions and sizes
2D top view
3D view
Trees with different directions
Rendered graph
YGYL
Re: Woods and grass
Post by YGYL »
If you don’t have a random distribution system, it takes a lot of time to do this kind of map.
If you can randomly distribute the specified multiple objects, including
Random location within range
Random size within range
Random direction or both directions
Range random machine height
Well, doing this is very fast.
YGYL
Re: Woods and grass
Post by YGYL »
My thoughts on Pre-segmented dynamic object system's custom user interface
Allow advanced user defined material library
It also provides ordinary users to define him in software.
This will be a great pleasure for software. I hope users can create some interesting things when using software. So there is no need for too many restrictions.
The whole process is reflected in a Script form. The software executes some items on the table down.
If set correctly, those cases in my front post will be reached.
After execution, a new object is generated in the object bar. Drag and modify this new object to automatically create complex objects.
Script form
Type is the most important column.Determines the function of this script.Other columns are his parameters.
left
Middle (simple)
Pattern 1
Pattern 2
Pattern 3
Right
corner
Inner corner
Outer corner
Random placement (square)
Random layout (circle)
Several choices 1 (Book)
Intermittent repetition
blank
Country: France
Re: Woods and grass
Post by VeroniQ »
Thank you very much, YGYL, for these models that I may use in a “Haussmanian” flat. Could you confirm that the 3D models listed on this page are available under Free Art Licence or CC-BY Licence? Thanks in advance
Bubblobill
Country: Australia
Re: Woods and grass
Post by Bubblobill »
I've been considering something similar based on a staircase constructing plugin.
