Hi Dorin,
I saw you mention this plugin in another thread and thought "Oh. That sounds useful as I try to deconstruct my plans to try and produce acceptable planning drawings.
Unfortunately it does not work for me, although it might just be me.
Plugin installed, show an Edit menu item and a tool bar item, but clicking either one does nothing. No error message either. Just nothing.
I don't have the conflicting plugin the text mentions, and I'm running latest (7.0j)
Have you tested it with 7.0?
Select Hide Utility plug-in
This topic has been viewed 18212 times and has 14 replies
Re: Select Hide Utility plug-in
I just tested the last version and it doesn't work when there is no level in the home, with the following exception:
Dorin, I hope this will help you to fix this bug.
Code: Select all
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.eteks.sweethome3d.model.Level.isViewableAndVisible()" because the return value of "utility.SelectHidePlugin.access$6(utility.SelectHidePlugin)" is null
at utility.SelectHidePlugin$1.execute(SelectHidePlugin.java:108)Emmanuel Puybaret, Sweet Home 3D creator
Thanks Emmanuel. I never even thought to test with a real file. I was just trying to check the plugin out on an new file with a few bits and bobs and never thought to add levels.
- dorin
- Advanced Member
- Country: Vatra Dornei, Suceava, Romania
All's of You have right! The fault is mine!
So, New version 1.6 .
- fix the bug previously mentioned;
- add Chinese translation (thanks to YGIL);
Reminder: this plugin work ONLY on & with objects at selected level.
Also on Source Forge .
Thanks Dorin, it's possible to select objects in a home with no level now [:)]
