@ enkonyito
Maybe this is not the right thread to discuss this, but I'm somewhat puzzled by the way Sunflow handles shininess.
It's like shininess is either on or off, with nothing in between.
I have done several tests on this, and I'm really wondering if the shininess slider has any function at all.
Is this just a result of the limitations imposed by SH3D, or is this a real Sunflow limitation?
Additional Sunflow options (tests)
This topic has been viewed 18873 times and has 13 replies
Re: Additional Sunflow options (tests)
@Ceciliabr
In the Furniture materials panel, [font=courier new]Matt=0[/font] and [font=courier new]Shiny=1[/font]. The Java 3D preview lets you see the difference in shininess.
When rendering, Sunflow applies a shader to the material that "changes" the shininess. (see pages 14 to 23 of Sunflow Wiki PDF)
Sunflow's standard configuration in Sweet Home 3D is based on several tests performed in 2010 (Test 1, Test 2).
Enko
In the Modify furniture panel, [font=courier new]Matt=0[/font] and [font=courier new]Shiny=0.5[/font].It's like shininess is either on or off, with nothing in between.
As Puybaret had told me : "There's no limitation".Is this just a result of the limitations imposed by SH3D, or is this a real Sunflow limitation?
Enko
EnkoNyito
* Option:
-bucket X Y
Changes the default bucket size to n pixels and the default order (BucketRenderer, MultipassRenderer).
Sunflow default value: bucketSize = 32, bucketOrder = hilbert.
SH3D default value: bucketSize = 64, bucketOrder = spiral.
SH3D implementation:
[font=courier new]int bucketSize = 16; // min = 16, max = 512
this.sunflow.parameter("bucket.size", bucketSize);
String bucketOrder = "spiral"; // hilbert, spiral, column, row, diagonal or random can be reversed
this.sunflow.parameter("bucket.order", bucketOrder);
this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS);[/font]
-bucket X Y
EnkoNyito
These options will no longer be managed in the next version of the photo-video rendering plug-in.
EnkoNyito
Users browsing this forum: Amazon [Bot]
