smile 2040 : Mars Two
This topic has been viewed 332463 times and has 199 replies
Re: 2040 : Mars Two
Post by bdfd »
Thank you Lady Vero. [:)]
The bricks are arrived at the cupola to finish the wall.
1920 x 1080 in Q4
The closer view shows the rover with its trailer (with 6x6 wheels).
Re: 2040 : Mars Two
Post by bdfd »
D 290
The assembly of the structure of the dome began.
1920 x 1080 in Q4
Captain hopes that it will be finish for the new year.
Re: 2040 : Mars Two
Post by bdfd »
12/31/2040
The captain is happy ! [:)]
The structure is finished... we can do the fest this night ! [:))]
Tomorrow in the evening (after a good night) we will install the inflatable cupola.
In the right background (1 km from base camp), we can see the site with its solar panel which produce Methane, water and O².
Re: 2040 : Mars Two
Post by bdfd »
All the crew on Mars wish you a Happy New Year (to) Earth !
1920 x 1080 in Q4
In the sky, you can see the fireworks and ISV Hermes passes over the base camp...
Country: Paris, France
Re: 2040 : Mars Two
Post by Puybaret »
Happy New Year to you, bdfd, your crew and all Sweet Home 3D users! Thanks for accepting to answer to our questions [:)]
Re: 2040 : Mars Two
Post by bdfd »
Thank you Emmanuel.
Long life and prosper !
01/01/2041 : The new year begins well (D 295), the inflatable cupola is OK.
1920 x 1080 in Q4
The crew will be able to live in while creating it.
Finish the 'little' accomodation module. [:)]
The dome is made up of 2 inflatable envelopes:
The first outer side (10 mm) is filled with ozone to filter the UV rays,
The second inner side (20 mm) is filled with water to protect from other radiations.
Mars will be able to host the next missions.
Re: 2040 : Mars Two
Post by bdfd »
Come back aboard the ISV Hermes and the last part : the Propulsion module.
1920 x 1080 in Q4
To protect the crew, there is a vaccum between the Accomodation module and the Propulsion module.
Re: 2040 : Mars Two
Post by bdfd »
Inside the airlock module, the crew sees the twice parts : front airlock and the main console of the engines.
Main console
Front airlock
1024 x 768 in Q4
After the silence of space, 'vrrrmmmmmmmmmmmmmm' the noise of the engines... [:))]
Re: 2040 : Mars Two
Post by bdfd »
We arrive into the machines room 'Scotty'... [:))]
1024 x 768 in Q4
there is Lot of noise and it's a hot location... [>:)]
Re: 2040 : Mars Two
Post by bdfd »
We arrive at the central part of the machines room.
1024 x 768 in Q4
